Important Wastegate Question
my battery is on its way to hell acid starting to come out so ...maybe theyll do me a favor for all my troubles...Yes i kno i have High hopes
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
ahh see u are good for something else besides talking shyt...thanks for that info...i told victor about the heat shield not being put back on nd he seemed mad...now i pmed him my address 4 towing purposes...hell be really mad after he sees that 96.01 miles to the shop
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
ehh well hes a nice guy...and hes trying to help me out...
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
T25 pick up pric3 50....only for today...need gas money for ride home from bvp
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
OK I forgot that this was a factory turbo car. YES, your boost source (whatever it may be) should have run from there, to the boost control solenoid, to the wastegate...HOWEVER, if you wanted to use a manual boost controller to raise the boost it should have gone boost source>boost controller> wastegate. The bov should have one line run off the intake manifold (because it must see both the boost and the vacuum to open and close) that is not connected to anything else. With this setup your bov will work, and your wastegate will work, and you will also be able to turn up your boost to an amount that you determine.
TR Old Skool EF Crew #24
thats not exactly an issue
i think my setup is
sourced from the BOV to the profec, then from profec to the wastegate
the wastegate is pushed open with boost pressure, all a boost controller does is bleed the boost off
i think my setup is
