6 bolt swap help
i need help i ave a 6 bolt block and a 6 bolt head but that is all. i need to know if the non turbo 6 bolt motor all the small thing will work on it like, oil pan, intake, sensors, and so on please help
Yes all those things are enterchangable and can be swapped between the turbo and non turbo engine. It is typically the same engine just with different pistons and no oil squirters.
Its like swapping into a 1g, you just need to use all 2g brackets,mounts and pullies. You will also need to use your throttle position sensor off of the 2g on the 1g N/N TB as the 2g harness uses the 4 proung sensor. Last I can think of currently you will need to get a 6-bolt swap conversion harness. This will connect the 2g crank sensor plug to the 1g style cam angle sensor plug. Be carful when ordering, you need to order for your specific yr car. www.Roadraceengineering.com sells it
http://www.roadraceengineering.com/p...g_n_play95.jpg
All I can think of for now sorry.
