95 gst help!!!
my friend just blew his head gasket....i was wondering how hard it will be to tear down the motor and fix it....it has a 98 4g63 swapped into it. We did a compression test and it ws all over the place....what should the stock compression be? the motor is stock....any advice is appreciated
The hardest part for me when i first changed out my HG was the timing. I had someone else come and do it for me. Everything is pretty straight forward just label stuff.
Headgasket is pretty much cake if you know what your doing. Timing on the other hand is a bitch. Atleast for me it is. I couldnt get it right to save my life. I had Drew at Darkside do my timing for me!!!
rocket science is easy if you're a rocket scientist...........
