i need help idleing problem
I have never heard of a "dealer code". I would get it scanned with a different scanner. I would definitely start checking vacuum lines. With the car running spray all the gasket surfaces of the Intake manifold down with carb and choke cleaner. If there is a decent sized leak you should hear the idle change.
ok news update i have no vacuum leak checked every line and no leack check intake gaskets everything no leaks at all what should i do please i need more advise please help this car is making me angry and i wanna race this teggy because he thinks hes hott shit and well hes not
please help
please help
ok new up date the ecu if fucked up so i need to get a new ecu now what a dumb fuck that put it in they used speaker wire what an idiot anyways and also found out my ac doesnt work bad compressor so ill take all the shit off my old car and put on this one but i need and ecu asap
The reason it's showing up as dealer code is because you probably have the obd II scanner. Anything 95 and earlier doesn't have OBD II on it and you will have to get the codes pulled at a Mitsubishi dealership.
