somethings wrong here???
Old Jul 13, 2008 | 06:17 PM
TSiRacer's Avatar
Killing Clutches Since 04
Default somethings wrong here???
Ok heres the deal. After replacing the o ring on my hard water pipe that goes into my water pump, I replaced my alternator with a new one. No more leaks or anything now, but when I get into the gas, its like theres somethng stuffed in the intake or exhaust. Either one. There is nothing in my intake or any other pipes or lines. I dont know if theres a leak or what the hell it is. Any ideas? My car ran perfect before I replaced the o-ring and the alternator. Pleez help
another note: this is only doing this at lower rpm's like in first when I'm first taking off. If I ease into it slowly, it will run fine( I guess). If i punch it it sputters and backfires.
I replaced my j-pipe gasket and finally tightened it up so Im not leaking anymore.
......keep it boosted....
Old Jul 13, 2008 | 06:47 PM
97blackwidow's Avatar
boost leak test
When you think you know everything there is to know,thats when you start to learn.
Chip Foose
http://www.teamrip.com/
http://www.importperformanceparts.net/
Old Jul 14, 2008 | 05:45 AM
GNEn!st's Avatar
AWD all the way
check ur coil packs ... that happened to me and that was my problem..just thought id throw that out there
Old Jul 14, 2008 | 07:31 AM
TSiRacer's Avatar
good idea. Just in case...how do you perform a boost leak test?
Old Jul 14, 2008 | 07:43 AM
heres the one i use
Build a boost leak tester for your to4e - DSM Forums
Chip Foose
Old Jul 14, 2008 | 07:52 AM
TSiRacer's Avatar
looks simple enough...but Im gonna sound like an idiot now. What or how do you use it when its done? Do I just take off my intake and cap the turbo?
Old Jul 14, 2008 | 08:09 AM
yep,right on the turbo inlet side.pressurize it no more then 30psi,bottle of soapy water,spray down the ic pipes/TB and listen for other spots.
Chip Foose
Old Jul 14, 2008 | 06:13 PM
Dario99gst's Avatar
Tu Papi Chulo
Did you remove your exhaust manifold to get to the water pipe?
Could be you forgot to tighten it all the way
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Jul 14, 2008 | 07:25 PM
TSiRacer's Avatar
yes I did. And thats what I've been wondering too. Actually, when i was tightening the nuts back up on my manifold, I broke the top left bolt. So I tightened up all the rest carefully, because I was scared i was going to break more bolts. But they are tight enough. I do have to figuge out how to fix that busted ass bolt though. Any ideas, or experience doing it?
Old Jul 14, 2008 | 07:52 PM
easy out and helicoil for broken bolts.
Chip Foose
