How do you....
check the fuel pressure on a 95 eclipse with a 98 motor?
My friend has one, and I'm a mustang guy, so I have no idea. He says he smells fuel under the hood, but sees no leaks, and the only code is one for the power steering pressure.
I had no idea that was even monitored.
Is it a Non turbo? If so there is a schrader valve that you hook up to on the fuel rail. You will be needing a Fuel pressure test kit. The kit I speak of comes with multiple adapters for all different makes and models.
