Trany problems!!!!
Hey guys i need help with this. i have no idea whats wrong. but heres what happened. i was at a dead stop in the car at neutral and went to shift into first. but it wouldnt go in. it wont go in any gear and yes the clutch is being pressed down lol. so i turnd it off and it went into gear fine. so i turnd it back on and it would not go into gear! Any ideas?
i think i might need a trany. anyone know where to get one???
did you check your clutch fluid?did you have someone get in the car and press the clutch to the floor and see if the slave moves?
check fluid
check slave
let us know how it works out.
check fluid
check slave
When you think you know everything there is to know,thats when you start to learn.
Chip Foose
http://www.teamrip.com/
http://www.importperformanceparts.net/
Chip Foose
I just went thru the same issue just this past tuesday,I changed out the slave as my was leaking when i pulled the boot back.but that didnt fix the problem so i pulled the tranny and saw what the problem was instantly,1 of the springs in the little helper springs had popped out of the clutch disc. Will also add that the car would idle fine and it made no noise at all while running,even when i pushed the clutch in.I would drop the tranny and check the disc.
"Sit right here pimpin,let daddy holla at ya,Now daddy can do this ALL DAY, EVERYDAY,NO PROBLEM". MAKE A PIMP DECISION
fluid is fine. that was the first thing i did when it happened. So i called Jeffs transmissions on dalemabry yesterday and a guy there said it might be the slave cylinder or something with the hydrolics. anyone think so or know of the place? im taking it to them monday. anyone know if they do good work?
sorry do all my own work,so no idea.
Chip Foose
Chip Foose
