Sliping out of 4th
Old May 19, 2008 | 09:32 PM
Buri3d's Avatar
Default Sliping out of 4th
At normal speed when you shift into forth gear it will stay untill you accelerate then the tranny pops/slips back into nuetral. Only happens in this gear. What could be the culprit and possible cost to fix? Im not big on the bottom end of things. I was told it could be loose bolts on the tranny wear the clutch meets, but I figure that would cause 5th to slip as well.
Thanks guys
"Throttle till you see light, then brake like HELL!!"
My Last.fm Top 20:
Old May 20, 2008 | 03:24 AM
GSX/SC's Avatar
The Living Dead
the syncro rings are bad--ur either going junkyard,or rebuilt
pm me,i can get u fixed up for cheaper than most
Moved to Pa
Old May 20, 2008 | 06:21 AM
lancerman's Avatar
it means your shift fork inside the tranny is worn. this happens when the car is driven with your hand resting on the shift lever while driving. the fork can long longer fully engage the gear so it pops back out. its not a syncro problem
my favorite quote
Old May 20, 2008 | 08:20 AM
Buri3d's Avatar
I dont think its the syncros because they usually cause problems shifting into gear not sliping back out. how much is parts+labor for a shift fork usually?
Thanks for the offer GSX/SC.
My Last.fm Top 20:
Old May 20, 2008 | 09:12 AM
lancerman's Avatar
if you bring me the tranny it will cost about 150, provided thats all thats wrong. its not uncommon to see more failing parts when the tranny is opened.
my favorite quote
Old May 20, 2008 | 09:56 AM
Buri3d's Avatar
Good price, Its on a 2000 Eclipse gs not the 97 on my profile if that matters. Do you work from home? Cuz I cant pull the tranny myself lol.
My Last.fm Top 20:
Old May 20, 2008 | 02:37 PM
chillllll's Avatar
11 second club
that may change things...a lot
10 sec street truck...
