Timing cover removal?
Old Apr 19, 2008 | 05:35 AM
DSMboost97's Avatar
How long will it last?
Default Timing cover removal?
What do i have to do to get my lowwer timing belt cover off? Looks like i just have to take off the accessory belts and somehow remove the crank pully.(4 small bolts on the pully right?)
I was under the car changing the oil and i saw something i didnt like, The timming cover is on crooked as hell somehow and its hitting the crank pully and makes a horrible whining noise that varries with the RPMs. Hopefully i can take the cover off and put it on properly, or at least trim it a little so it stops screaming.
Old Apr 19, 2008 | 10:35 AM
minitruckinxxxx's Avatar
best bet if your trying to take it off to leave it off for good i would think is cut it off. I know on the 420a dude that was the worst part of changing the timing belt. there was 3 long bolts that you had to jack the entire engine way up to get out and lower way down it was a NIGHTMARE no explaining it. the crank pulley was hell to get off too. $120 to rent the tool at advance
Old Apr 19, 2008 | 12:40 PM
Black_Bullet's Avatar
**Dont disturb,Sleeping**
I dont have mines on anymore ever since i did new timing belt and cam install. Mines was crooked too and getting ate into the gears.
Officially Dsmless...
"America remains one nation, under drugs, indivisible, with perceived liberty and sickness for all." - Shane Ellison
