Car won't start only crank (GS-T)
OK here's the deal, I've changed ICM the coil pack and now just the CAS but still no spark. I can't figure it out but its getting to the point that it is crucial to get my car running. I would appreciate it if any one can point to a diagnoses that it could be.
Chink
Chink
Rip Big Brother, Sgt Christian B Williams 11/29/78-7/29/06
Mazda 2 Forums
R.I.P. Pablo 'Fathead' Garcia - Love you man! See you on the other side!
R.I.P. Kevin 'Slo_Si' Gonzalez - You will be missed!
Mazda 2 Forums
Did you plug the coil plug back into the coil pack,did you reconnect the power transistor plug ?
"Sit right here pimpin,let daddy holla at ya,Now daddy can do this ALL DAY, EVERYDAY,NO PROBLEM". MAKE A PIMP DECISION
I pluged every thing back in and all it does is just crank n its not crank walk lol
check timing belt? just saying cuz we replaced timing belt and had a tooth off and had no spark.. so maybe if your timing belt is brokkkke then you wont have spark either rightttt lol.. check it.. lol
it was running b4 but when i did a 14b swap one of the water lines bursted while i was driving (dont know how it did maybe a lil brittle i guess) and it overheated a little then i fixed the line ans put water in t after an hour then tried to start her up but she just cranked n thats all so i started replacing things.
yo when yu bought that car did they tell u anything was wrong with it?? cuz i kno u havent had it too long right..
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
When i bought it i was screwed and then i had to put in a new motor and ever since then it was problem after problem but she was running ok for awhile then this happened, and no im not gona sell it.
