DSM head question
well I got the dsm and all is well except there appeasr to be an exhaust leak between the manifold an the head. I bought a gasketa nd the manifold looks easy enough to yank off but it also appears that the culprit is a broken stud on the bottom drivers side of the manifold how hard will this stud be to remove?? Is this something I can do ina day provided I can get the damn manifold off
Also the manifold appeasr to have a small crack in it about 1 long but no leaks appear to come from it who makes a nice replacement headr I can put in there but I am still going to do the gasket repar b/c I dont wanna burn any valves but evetually I will put a header there if they make one.
A good upgrade is a stock 95+ manifold. They have much bigger runners. They all crack at some point. If the stud gets stuck and easy out works wonders. Other then the 95+ mani you will pay out the a$$ for a header of any sort.
Tony there is an issue with puting the 95 manifold on a 90-92. Two of the studs are a different size on the 92.5+ . Its the outer two. I did not have to deal with it in anyway because mine is a 94 but EmoDSM would know.
I think I paid 90 something for one from Courtesey Mitsu. If you have a dies grinder open up the runners a bit. Just gasket match it to the head. When you put on the 16G you can port out the hole to match the turbo inlet.
Originally posted by "Someone"
Originally posted by TealTalon
Hrmmm no problems putting Bills mani on Emos car.
http://www.vfaq.com/mods/porting-exhman.html
this says you can use the 8mm outer studs without a problem. Dont worry about it then Tony!
I had a friend with a 90 and we didnt have to do anything to get the 95 head on now for bolts instead of studs I wouldnt replace them with bolts because the head is aluminum and is VERY easy to strip out
