Sticking Gears
Old Oct 24, 2007 | 11:07 AM
Jasoninsane123's Avatar
Exclamation Sticking Gears
ok i got a 2002 lancer oz rally just had the clutch replaced and it sticks in 1st and 2nd it wont go into 1st unless im under 10-15 mph is there anything i could do to fix this problem dont seem right to me at all
o and what else can i do to make it a lil faster
Old Oct 24, 2007 | 01:05 PM
DSMboost97's Avatar
How long will it last?
Road Race is your best friend.
Lancer 02-06 : Road Race Motorsports, Road Race Motorsports
Old Oct 24, 2007 | 01:07 PM
cyloc's Avatar
TR Shop Mod
If you are talking about it sticking when you are down shifting, stop down shifting into first. It is not good for the trans if you down shift to first. There is a large amount of torque in first gear, that is meant for you to accelerate not slow down.
With it sticking, you may need to adjust the clutch pedal to give it more hydralic flow or check the shifter cables.
Making it faster....I am guessing by your pic you have a OZ Rally.....the usual...intake, exhaust, headers, cams, tune.....basically mod the shit out it....or sell it and buy an EVO
JUDGE RACING
Old Oct 24, 2007 | 01:38 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
usually with a new clutch you may need to adjust it
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Oct 25, 2007 | 09:05 AM
its not when i down shift its when im at around 10-50 it sticks when i put it in 1st to get more speed its always done this really didnt care but now i do its geting no better
and even 5mph it sticks and pops out of lst when its in N and its tricky to get into R i have to let off the clutch a lil for it to go into R
Old Oct 25, 2007 | 12:39 PM
cyloc's Avatar
TR Shop Mod
Sounds like your clutch needs to be adjusted. If the pedal is to high, it can cause what you are taking about. It actually sends to much fluid through the line when pushing the clutch in. It can cause it to push and pull it back after to much goes through the line.
JUDGE RACING
Old Oct 25, 2007 | 01:17 PM
yeah where is the best place to get it adjusted im thinkin brothers racing
Old Oct 25, 2007 | 02:15 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
yea sounds like its adjusted too far out, and its not getting enough throw in the clutch slave rod.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Oct 27, 2007 | 05:02 AM
CiViC_PrInCeSs89's Avatar
just adjust your clutch and you should be good
Old Oct 27, 2007 | 06:16 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
well it may or may not be the problem, but its probably the best place to start since its real easy to do
-Dane
98 240 w/ bolt-ons
Srqspeed.com
