ECU problems
Old Aug 26, 2000 | 07:41 AM
OldGuy's Avatar
Anyone have a spare ECU for a 90 GSX? I think mine is fried and I hate to spend $300 on a rebuilt just to check! Or is anyone willing to try mine in their 90 AWD?
OldGuy
90 GSX
13.0 @ 114mph
Old Aug 26, 2000 | 12:04 PM
Blood_Sun's Avatar
If all else fails try http://www.car-part.com and search there. I came up with this and it seems pretty reasonable.
1990
Mitsubishi
Eclipse
Engine Computer
ECU 2.0L AWD FED-
$250.52
9D617
Advantage Auto Recyclers
1-800-838-9901
Old Aug 26, 2000 | 02:07 PM
MitsuBucci's Avatar
Olde Skool DSM'r
Nice research skills Blood_Sun. I couldnt have done better myself.
OldGuy I have a 94 AWD and I know the ECU is different or maybe I could help you. I have a friend that has a 90 GS-T parts car. He may be able to help you if that ECU will work.
On another note...
How did you run 114 MPH with only a 13.0 E.T.?
Joe
94TSiAWD
http://www.cr-racing.com/talonpage.htm
13.001 @ 106.55
Joe B.
Wrenches, Races & Rides
Old Aug 26, 2000 | 02:39 PM
gsx eclipse's Avatar
you know i belive i can help you oldguy my car si down for a few days /weeks . (dont ask) but if you live near me i cold lend it to you to check if thats the prob.. let me knoe i live in tampa
alex galvan
13.89 @ 91mph
alex galvan
13.89 @ 91mph Stock!
Old Aug 27, 2000 | 06:20 AM
OldGuy's Avatar
I think Ive found the problem. The MPI relay (that click noise after you shut down the engine - 15 seconds later) shows an open circuit on one of the relays. To confirm though I cant get a replacement until Monday.
The 13.0 @ 114mph was a missed gear! I was also cutting out @5000rpm (bad spark plug gap) running off the battery (decaesed alternator) and the X-Fer case seized 4 miles from the track! Since then Ive made some upgrades and IF I can hook and hit the gears Im hoping for low 11s.
Old Aug 27, 2000 | 06:29 AM
MitsuBucci's Avatar
Olde Skool DSM'r
Originally posted by "Someone"
Alright cool. Well Good luck to you.
Joe
94TSiAWD
13.001 @ 106.55
Joe B.
Old Aug 27, 2000 | 05:52 PM
GSTSuper16G's Avatar
Clicks coming from under the dash are a tell tale sign of leaking caps in your ECU arent they?
Old Aug 28, 2000 | 02:57 AM
MitsuBucci's Avatar
Olde Skool DSM'r
They all click when you shut the car off.
Joe
94TSiAWD
13.001 @ 106.55
Joe B.
Old Aug 28, 2000 | 06:12 AM
16gAWD's Avatar
Mine clicks too around 12 secs after shutdown. That is when my S-AFC shutsdown too.
16gAWD
97 Talon TSI AWD
James
Just another unreliable fast DSM
http://www27.brinkster.com/awd16g/
Old Aug 28, 2000 | 06:54 AM
OldGuy's Avatar
The click you hear from the center console about seven seconds after you turn the engine off is the ECU power relay shutting off killing power to the ECU. I replaced this and unfortunately it did not solve the problem.
I have replaced the ECU with the Todd Day upgrades (sutter box launch RPMs etc.). The company which sold me this E-PROM ECU claims there is nothing wrong with it. I have chased down a lot of the wiring and I have not found any problems with my car either!
