safe boost?
Old Jul 24, 2000 | 02:58 PM
FastFour's Avatar
how much boost is safe to run on stock internals on a 2g with these mods. http://eclipse.isni.net/mods.htm
cause im around 19psi sometimes (w/ a little race gas) and i take into consideration my boost gauge is prob off a little. Whats the highest i should run before i blow the head gasket?
Frank
99GS-T
Frank
99GS-T
Old Jul 26, 2000 | 07:54 AM
The^Thief's Avatar
The Max boost I would run on the car and this is for track only is 21psi. After that you may watch those stock head bolts start to stretch. Plus you are still working with the weak 2g bottom end which I wouldnt trust past that level. Ive successfully run that boost level on my car and so have a few other TB DSMrs.
V8 SLAYR
Jeff Peterson - 2006 GTO - Cold Air Inductions CAI, SLP U/D Pulley, FAST Ported Intake, Ported TB, Kooks 1-7/8's, Spintech Mufflers, H-Pipe, Yella Terra 1.7 Rockers, Flowtech Hellion Cam, 255lph Pump, and GMM Ripshifter. 445rwhp 402rwtq SAE
