part question
Old Sep 21, 2007 | 03:50 PM
GNEn!st's Avatar
AWD all the way
Default part question
what is the benifit or downfall of changing out a 2g intake manifold to a 1g intake manifold. Also how much improvement will a 1g throttle body make on a 2g? thanks
Old Sep 21, 2007 | 04:22 PM
THE_ONE's Avatar
*Turbo Interceptor*
No improvement, it will actually cause a leak, being the 2g ports are smaller than 1g ports. If you change the intake mani you will have to change the head too. Or you can epoxi the runners in the 1g mani to match the 2g head. The only manifold worth the throuble would be a cyclone intake mani with dual runners.
Oh and if you change the throttle body, go with a 1g non turbo TB with the snout, its the biggest oem one you can get and it allows alot more air flow than the stock 2g.
Hope that helps!
Old Sep 22, 2007 | 11:06 AM
GNEn!st's Avatar
AWD all the way
what if i got a turbo 1g throttle body, wouldnt be better than my stock 2g?
Old Sep 22, 2007 | 02:49 PM
GsT Racer's Avatar
back in a 4g63
first of all, a 1g (6-bolt) intake manifold wont fit onto a 2g head. the bolt holes do not line up.
second, as far as the throttle body, it would fit. BUT the hole is bigger than the opening of a 2g intake manifold, which would result in the air bottle-necking.
what you COULD do is put a 1g head on your stock 2g block, and therefore use the 1g intake mani and tb. plus, the 1g head flows a lot better than a 2g head.
Old Sep 22, 2007 | 04:38 PM
Skyline Driver 5's Avatar
round and round it go
so that means that the cyclone manifold wouldnt fit on the 2G head either right? and dont you have to drill holes on the 2G block to fit the 1G head? So really you cant put anything 1G (throttle body, intake manifold) on the 2G head anyway. no point unless you have a 6-bolt swap.
TR "Old Skool EF" Member #150
Old Sep 22, 2007 | 05:40 PM
GsT Racer's Avatar
back in a 4g63
negative 6-bolt head bolts right up to a 2g motor. im actually in the process of doing that.
Old Sep 23, 2007 | 06:29 AM
2ndGenDsm's Avatar
dont you get that mysterious "phantom misfire" issue if you put a 6 bolt head on a 7 bolt block....or is that a 7 bolt head on a 6 bolt block....in any case why dont u just go ahead and the whole 6 bolt swap and call it a day?
and now introducing my newest toy...
-Silver Slow-poke-
Old Sep 24, 2007 | 03:19 PM
GNEn!st's Avatar
AWD all the way
lol yea the six bolt swap, its definetly goin in when this motor goes.
Old Sep 24, 2007 | 11:00 PM
THE_ONE's Avatar
*Turbo Interceptor*
it can happen when you swap a 6-bolt into a 2g period. I had it and I got rid of it, there are ways around everything
