timing off= turbo lag?
OG MUDBONE 240sx
so i just finished my headgasket, and i think the valve timing may be advanced a tooth. when i get on it, the boost goes up to about 20psi, it doesnt go up very fast, and it creeps to about 24psi. i even pulled the line off the wastegate to see if it was just the boost controller, but it still did the same exact thing. car runs fine and all, but wont boost very well. it almost feels like its at part throttle.
Srqspeed.com
-Dane
98 240 w/ bolt-onsSrqspeed.com
ur blowing headgaskets because ur either not doing it right or ur runing to much timing on ur setup fool.
98 talon awd automagic
Advancing both cams or just the intake cam will bring the turbo on faster adding to the mid range power.
Advancing just the exhaust cam will add top end.
Check for a leak at the wastegate.
Tom
Tom
OG MUDBONE 240sx
ill check, now i did verify that the timing on the cams were off. i set the timing again and the boost does come on harder, but its still only hitting 20 and creeping to 24psi. ill check the wastegate and the manifold though.
Srqspeed.com
-Dane
