Meth or nos
did the same with my suby, 28psi on 93/meth setup. good fun
meth all the way !
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
No way cooling mist is way better!!!
...not
...not
“It’s amusing to find that the road to success is never convenient however the road to failure all most always is...”
-S. Charles
"Excuses are monuments of nothing built by tools of inequity and those who use those tools will be masters of nothing"
-Unknown
"Time is a luxury that even the richest man cant buy"
-Unknown
1990 Talon TSi AWD
Joshua P.
-S. Charles
-Unknown
-Unknown
1990 Talon TSi AWD
Joshua P.
Two totally different things, like Rob said.
Meth works to prevent knock which allows you to run more aggressive timing and higher boost levels. It basically burns like a higher octane fuel than pump gas and it cools the intake temps which also suppresses knock.
Adding meth to your car RICHENS your tune, it is a fuel.
Nitrous is an oxidizer it LEANS your tune, it is a power adder but you need to add more fuel to compensate for it. It also cools your intake temps similar to meth.
I'm certainly not an expert, but that's how I understand it.
Either way you'll need a tune, meth is more of a cheap replacement for race gas whereas nitrous is a power adder by itself.
Kitt said most of what needs to be said about both. Just be sure if you go the meth route. You have safe guards in place for when, not if, the pump fails
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
indeed julio put mine in
so you can lean out your tune and get better gas mileage!! w00t w00t
lol
lol
woah waohh
lay off the meth guys, thats bad drug use.. i can't imagine what you do with the nitrous! probably laugh a lot.
jk
meth seems to lay down some sweet tq/hp streetable numbers, and clean your intake out
meth all the way!!!
meth is 4$ a gallon.
a half gallon of it (container) will last about (streetable cars)5-12 runs down the 1/4 mile depending on how much you need to run your car (higher hp/more meth).
jk
meth all the way!!!
