clutch popin
Old Jun 29, 2007 | 04:35 PM
Jasoninsane123's Avatar
Default clutch popin
i got a 2002 lancer oz rally some times when i shift out of frist it Pops REally Hard ?????
Old Jun 29, 2007 | 06:25 PM
GoodFella813's Avatar
thats cause its a dsm and dsm suck haha jk
Old Jun 29, 2007 | 06:28 PM
Old Jun 29, 2007 | 07:25 PM
AnthrAxNSB's Avatar
first
What pops? Are we talking about a sound, or a movement (e.g. the shifter pops out of gear)? If we're talking about a sound, from where?
Old Jun 29, 2007 | 07:46 PM
out of gear
Old Jun 30, 2007 | 07:50 AM
AnthrAxNSB's Avatar
first
So, you're in first, depress the clutch, and start to move the shifter and it pops out on its own?
This is either a problem with cable adjustment or internal (transaxle).
Old Jul 1, 2007 | 06:28 PM
omgosh's Avatar
Could be the cable mounts getting loose or something like that...the clutch system is pretty simple, just get under the hood and follow the cables from the center of the firewall to the transmission. See if anything is loose, rubbing, whatever. Like anthraxnsb said, look for an adjustment and try that out.
On my car, I had a broken front motor mount. Sometimes when you gave it enough gas in the lower gears, it seemed like the motor was rocking around when you let off the gas and causing the shifter to violently pop out of gear as soon as you hit the clutch. But you could probably tell if you had a broken motor mount.
Old Jul 1, 2007 | 09:02 PM
Alright thxs alot i keep u guys posted hope this will fix it
