Crankwalk or something else?
Old Jun 11, 2007 | 07:40 PM
Skyline Driver 5's Avatar
round and round it go
Default Crankwalk or something else?
I just bought a complete 7 bolt for cheap and I think it crankwalked at 111k then was rebuilt but didn't run again after the rebuild cause the mechanics forgot about the crankshaft angle sensor, reason being is because they said it "wouldnt start anymore." How can I tell if this engine has problems besides dropping it in my car and potentially ruining my crank sensor? I took off the oil pan and I cant seem to find any problems but i could be wrong. What should I be looking at? My original engine spun a rod bearing on #2 and im not taking apart the block and throwing away money. My original solution was you guessed it a 6-bolt but I got this engine for cheaper. So before I swap it in, what should look at, on this engine? Also its a 95-96 engine, do I need to fabricate anything to accommodate my 98? Im clueless
TR "Old Skool EF" Member #150
Old Jun 12, 2007 | 03:01 PM
Todd's90's Avatar
0711, USMC
from what I remember, crankwalk can not be fixed with a rebuild. somebody correct me if im wrong
1990 GS-T
1990 GST
2004 BMW 325i
Old Jun 12, 2007 | 03:11 PM
Gooser's Avatar
has his own parking spot
crankwalk occurs because of an oil passage on the 7 bolts being smaller and it grimes up...meaning drop in oil PSI, and no oil PSI means? thats right people not good....basicly 7 bolts are shit and it will run good with a rebuild but only way to ensure utr wont happen againcwould be to go with a 6 bolt block
Old Jun 12, 2007 | 05:52 PM
Dario99gst's Avatar
Tu Papi Chulo
Wow 7 Bolts are shit!!!
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
