Shredder is back, for real
Picking up where we left off. Every click on the boost controller netted nice gains. At 34psi she laid down 597whp/517tq. This is with boost increased at higher rpms to limit the torque a little. Not wanting to stop 3hp shy of 600 we set the boost to 35. Problem with this is the 3.5 bar map only reads to 35psi. So if the boost goes over 35psi the boost controller doesn't try to compensate because it still thinks we are at 35psi. So for an unknown boost level she layed down a very pretty 622whp/567tq. no knock. This is on 93 octane and alkycontrol meth injection.
here is a rundown on the setup:
shelf stock JE 8.5-1 stroker pistons
eagle rods
factory mitsu 100mm crank, nitrided
7 bolt block with balance shafts for smoothness.
7 bolt head with intake ports widened to match 1g port width.
cyclone dual runner intake epoxy filled to reduce port height to match 7bolt
crower 414 cams
880cc injectors
evo8 valves, evo8 springs and retainers
mild street port by jerry
2g manifold with adapter to mount GT35RLS
tial 38mm gate
3 inch exhaust with quiet magnaflow muffler
best hp on old setup was 567/511. it was sick fast at that level.
Brad Brooks is the man. His tuning skills are second to none.
eagle rods
crower 414 cams
880cc injectors
tial 38mm gate
my favorite quote
my favorite quote
Jesus Christ. I wanted to be there for that. Damn Jerry, you should have called. I was right down the road at Good Time Charles. Oh well, maybe tomorrow, I will somehow find a way over there and get a ride. That is alot of power. You plan on posting on the evom forum?
I like how it sounds FWD spinning the shit out of 2nd hahaha ..
Great job Jerry and Congrats .
I also concur that Brad Brooks is by far the best tuner that I have seen
Hondata saves lives
Hondata saves lives
Ps Brad brooks is the shit
I will be by today for a ride
Congrats on a sick setup
Are you going to get a differant map sensor and push it farther?
^^^^^If you want what you pay for from a trustworthy shop Go to ^^^^^^
............^^^^^If you want what you pay for from a trustworthy shop Go to ^^^^^^
