idle surge
Old May 22, 2007 | 09:20 PM
xCLoVeRxG's Avatar
vtakkin
Default idle surge
whats a good way to get rid of idle surge? i have a 94 gst 6bolt, any ideas would be great.
Old May 22, 2007 | 09:24 PM
sm6989's Avatar
Rick Rollin
ISC sensor maybe? I got a few laying around if you need one.
I Rick Roll in your sleep
Old May 23, 2007 | 03:54 PM
soccerplayaz16's Avatar
check your idle set screw on the throttle body. they have a tendency back out becasue of vibration. there should be a little black rubber cap covering it that helps to keep it in place. start the car and turn it until it idles correct.
Old May 23, 2007 | 04:04 PM
Figs's Avatar
^It's hard to find 1g's with that black cap on the TB now-a-days, I've only seen one in person that still had it. Best thing to do if the cap is not there it pour some silicone and let it set so then the screw can't back itself out.
Usually the cause of idle surge is the ISC (Idle Speed Controller) but there's other various components that can cause it as well.
Go to VFAQ Site - Visual Frequently Answered Questions and their should be a idle surge faq there... I think there's also one on Talon, Laser, Eclipse 1G Info DSM. You'll find most your answers there.
Old May 23, 2007 | 06:58 PM
xCLoVeRxG's Avatar
vtakkin
thanks for all the info, and as far as the idle screw goes, ive adjusted that many times and it doesnt help the idle surge for when i depress the clutch, but i will look into the other info
