Battery Voltage all over the place
Old May 20, 2007 | 06:58 PM
slowy's Avatar
13.04@104mph
Default Battery Voltage all over the place
my normal bat voltage would usually run around 13.8 or so. now it bounces anywhere from 14.3 down to 10.8 (when i hit the brakes at idle. When cruising at 2500 rpm and use the blinker, it resets my EGT guage (electronic gauge with opening and closing full sweep)
hitting the brakes also makes ALL the lights dim. dash, headlights, afc all dim a LOT.
radio on or off seems to make no difference.
sounds like my alternator is going out, any other suggestions? (never had this happen before)
thanks
Old May 20, 2007 | 06:59 PM
Dario99gst's Avatar
Tu Papi Chulo
your diagnosis sounds correct.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old May 20, 2007 | 07:24 PM
eclipsegst303's Avatar
.:DSM:.
Mine does that sorta....When driving it will be at 13.5 - 14 and at idle it will drop to 12.8 and my radio will turn off and back on if loud enough. It's done it for a loooooong time tho, so I don't think my alternator is on the verge of dying unless its been about to die for 2 years.
Old May 20, 2007 | 08:25 PM
Todd's90's Avatar
0711, USMC
you don't remember ever doing it so I say we just do it before you end up stranded
1990 GS-T
1990 GST
2004 BMW 325i
Old May 20, 2007 | 09:06 PM
JR.'s Avatar
JR.
volt regulator inside the altenator is bad , u need a new altenator. this is the same shit that happend to my car 3 days algo, but it was going to 16v and my battery started spiting acid everywhere lol.
98 talon awd automagic
Old May 20, 2007 | 10:32 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
The voltage regulator in my generic reman alternator went bad twice. Both times voltage pegged to over 18 volts. My whinebro suddenly went nuts and hit a new high note, my headlights went HID and the interior lights all brightened up.
One thing I wonder about- is the battery also bad? It might just be starved for a charge because the alternator is failing. The battery should keep voltage up above 12 even if the alt shuts off unless it doesn't have a full charge on it.
Old May 21, 2007 | 02:59 AM
JR.'s Avatar
JR.
hahah same shit my car did, that shit was crazy.
Old May 21, 2007 | 04:49 AM
slowy's Avatar
13.04@104mph
wasnt intermittent though, just happened and bang, done.
looks like im in the market for a new alternator
Old May 21, 2007 | 02:50 PM
Todd's90's Avatar
0711, USMC
yea because im really tired of always having to push your car home.. or run 4 miles to your house to grab tools !!!! good times.
1990 GS-T
1990 GST
2004 BMW 325i
Old May 22, 2007 | 03:30 AM
DSMboost97's Avatar
How long will it last?
Happend to me once before, at idle with the headlights on and putting the windows up, when the windows got all the way up and i held the switch, it pulled enough current to actually stall the engine. It only happend once though.
