Need some help...
Old May 11, 2007 | 10:04 AM
mitsu4g63t's Avatar
Almost A Civilian
Default Need some help...
I need to relocate my tranny cooler from the left side to the right side (where the smic is) of my 2g gst (automatic obviously) in order to connect my fmic piping, anybody ever done this before?
Old May 11, 2007 | 02:20 PM
So_Sli's Avatar
It'll be a LOT easier to just re-adjust the IC pipes....otherwise you're in for some fun times.
Old May 11, 2007 | 05:06 PM
mitsu4g63t's Avatar
Almost A Civilian
The pipe doesnt adjust, it's a 90 degree angle that's mounted the hot side of the ic and goes back toward the engine.
Old May 12, 2007 | 12:34 PM
mitsu4g63t's Avatar
Almost A Civilian
it doesn't work anyway. the damn tranny dipstick won't let the pipe go from the tb elbow to the ic. I give up. this is my second fmic and still nothing.
Old May 12, 2007 | 12:44 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
just bring it to someone if you really do give up.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old May 12, 2007 | 02:14 PM
So_Sli's Avatar
What intercooler kit is this, and where did you buy it?
Old May 12, 2007 | 03:25 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
just get a different pipe for the hotside and reroute the piping a bit. you can get 2 1/4'' mandrel bent stainless piping pretty cheap
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old May 14, 2007 | 11:08 PM
50TRIM's Avatar
I would not worry too much about it, you can use a wide variety of heat transfer units. Some are as simple as the Harley Davidson oil cooler units. Just make sure the tranny fluid is cooled sufficiently with what ever means fits your setup meaning you may need more cooling on a boosted or sprayed vehicle. Air or liquid cooled should work fine. If you are having trouble finding a place to mount it (fit), use something else. i.e From a different vehicle from the junk yard with a tranny cooler.
www.gearracing.com
