Almost done
Update on motor
Just put on the evo 9 mr tb
Working on Downpipe now. This is just a mock up pipe
Still have get it to 90 back aroud.
And here is the aeromotive fpr.
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
I did, but I pulled it cuz I over heated it. Well a friend overheated. Long story short. It started knocking thought I spun a rod bearing pulled motor, fidanza flywheel bolts came loose.
Now I put 272 280 cams in and putting 35r on, since the motor is out. Alot easier to do with it out.
The rear main from where the flywheel came loose was a little ruff, took it to a machine shop they said it wasnt that bad. The cut the mains .001. He said that the nitrating was still there though. That the nitrating was fairly deep.
