Need Help no boost
Old Apr 14, 2007 | 03:07 PM
pzak's Avatar
Default Need Help no boost
Hey, just got an 04 evo 8 today and think it has a boost leak. The car is not pulling at all doesnt feel like 272hp. The intercooler looks dented, could it be the bov or diverter valve. All the hoses are tight, im not new to turbos just new to evos. And it seems that my old vw gti with a 1.8t was faster at only 180hp. would appreciate the help. thanks Rob
Old Apr 14, 2007 | 05:45 PM
TrboANTsi's Avatar
FL,..gods waiting room!!
well if you dont have a boost leak tester get a spray bottle and fill it with soapy water. turn your car on and just start spraying at all the connections and clamps and by the dents on the intercooler. wherever it bubbles theres a leak
Old Apr 14, 2007 | 07:12 PM
Moses's Avatar
you could also be experiencing drivetrain power loss. Dont quote me on that but your gti probbly had more touque than the evo. Boost leak test it and find out what it turns out to be.
Old Apr 15, 2007 | 05:27 AM
byondevl's Avatar
Made Of Scars
you are birdman arent you?
Old Apr 15, 2007 | 11:48 AM
pzak's Avatar
I cant find a boost leak, i hooked up a boost gauge and im getting 10psi is that normal?
Old Apr 15, 2007 | 01:25 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
no, maybe the car is in limp mode? is there a CEL on?
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Apr 15, 2007 | 01:34 PM
Moses's Avatar
dont quote me with stupid remarks i ant no bird.. thats a man also...
im moses get it straight!!
Old Apr 15, 2007 | 01:37 PM
Moses's Avatar
you dont hook up a boost gauge to check for boost leaks
you pressurize you intake system to about 25psi and you hear if any air is leaking out. check and retighten couplers, make sure all vacume lines and hoses are properly tight, then hook the tester up and pressure test it.
you can buy boost leak testers online fairly cheap.
try ebay.com
Old Apr 15, 2007 | 04:27 PM
pzak's Avatar
I dont have a boost leak, come to find out the boost actuater that controls the boost to the wastegate is bad, I took off a hose from that and now i'll get 15 to 17 psi..Thanks for your guys help
