1st to 2nd grind
Old Mar 29, 2007 | 09:48 AM
TrboANTsi's Avatar
FL,..gods waiting room!!
Default 1st to 2nd grind
i need some opinions. beforei came to florida my car was shifting great never a grind. before i made my journey here i changed all the fluids. and put BG2 in the tranny..and i noticed up here it grinds 1st to 2nd bad. i have ot shift at 2k for it not to grind.. my question is..could it be my fluid is too thin, especially with the heat..i was thinking of trying redline shckprf since its thicker and no blending fluids althought i heard mtl 90 is good too. but i want to make sure..what are you thoughts. or do i have to come to the fact that all of sudden my synchros are jacked?
Old Mar 29, 2007 | 10:58 AM
Todd's90's Avatar
0711, USMC
sounds like synchros are jacked, the car won't shift without grinding at higher rpm because the synchros are to worn to bring the spinning gear to a stop. I thicker oil might help alittle but you will eventually need to rebuild
1990 GS-T
1990 GST
2004 BMW 325i
Old Mar 29, 2007 | 02:10 PM
LS1Fever's Avatar
Try royal purple. You can find it at pretty much any automotive store for about $7/quart.
Old Mar 29, 2007 | 02:20 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
i just got 3 quarts of royal purple, and it was 10 bucks a quart
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 29, 2007 | 02:24 PM
TrboANTsi's Avatar
i was thinking my synchros are bad but then again it happened right after the fluid change.. i mean before the change i never ever had a grind.is royal purple thicker then BG2?.and are there any downs to running full shockproof?
Old Mar 29, 2007 | 02:30 PM
flybyuin2.2's Avatar
Royal Purple wholesale is $7 and retail $9-11 as far as running straight shockproof it is too thick and will cause hard shifting, replace the 2nd gear synchro and no more grinds
Old Mar 29, 2007 | 02:56 PM
Figs's Avatar
Isn't a better combo shockproof and synchromesh? Or am I just repeating the same stuff as above.
Old Mar 29, 2007 | 03:05 PM
TrboANTsi's Avatar
ok welli have one bottel of shockproof left and 2 bottles of BG2 think i should empty the tranny and and mix?
Old Mar 29, 2007 | 03:49 PM
LS1Fever's Avatar
Ditch the stuff you have and get royal purple. Drain your tranny fluid and flush it with automatic transmission fluid. Drive it around for about 10 miles with the auto tranny fluid and then put the royal purple in there. It will be a night and day difference.
Old Mar 29, 2007 | 06:01 PM
TrboANTsi's Avatar
ok so wehre can i pick up some royal purp around here?
