knock sensor
Old Mar 20, 2007 | 07:49 PM
GsT Racer's Avatar
back in a 4g63
Default knock sensor
can lifter tick really cause a knock sensor to change timing? if the timing IS being changed, would that cause a bad idle? is there any way to see or monitor what the knock amount is, and is there any way to disable it to see if it makes any difference?
im taking a lot of stabs in the dark here to see what could cause a bad idle.
Old Mar 20, 2007 | 08:01 PM
chillllll's Avatar
11 second club
crankwalk...
10 sec street truck...
Old Mar 20, 2007 | 08:07 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
i have had 13 degrees of timing pulled because of lifter tick. i have my settings for knock readings set to read above 2600rpms though. i think at idle, the rpms would be so low that the lifter tick would make it read a low knock count since its a very slow tick at idle. i doubt thats the problem.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 20, 2007 | 08:22 PM
GsT Racer's Avatar
back in a 4g63
so you are saying that because its a slow lifter tick, it wouldnt read enough knock to drastically retard timing or anything, at an idle? you know that makes sense, the car (usually) accelerates ok even when it is idling bad, so thats probably not timing. good point. the hell is the problem then
Old Mar 20, 2007 | 09:10 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
how much fuel have you added in to your idle?
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 21, 2007 | 04:15 AM
GsT Racer's Avatar
back in a 4g63
as far as the afc....its set to -5 at 1000 rpms.. is that what you mean?
Old Mar 21, 2007 | 08:20 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
yea on the afc. try to add in fuel. my car wouldnt idle unless i added in 15 percent fuel at idle.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
