4g63 in starion
Old Feb 14, 2007 | 12:34 PM
byondevl's Avatar
Made Of Scars
Default 4g63 in starion
What is the Toyota tranny that works?
Old Feb 14, 2007 | 12:58 PM
DC Dave's Avatar
Heavy Artillery Co.
i dont think so... i actually think the stock starion tranny will bolt right up to it... check out bushur with their 4g powered conquest.. its not a stock tranny but i believe its the starion tranny built
Old Feb 14, 2007 | 01:49 PM
TrboANTsi's Avatar
FL,..gods waiting room!!
one of my boys from ny has a 63t in a starion i asked and he said hes using a dodge d50 2.0 2wd tranny. he said it was pretty much a bolt on affair. Hes being gay so thats all the info i could get.
he said hte hardest part was getting hte clutch to work
drill a fwd dsm flywheel for the pilot bearing and get a custom clutch
TaLoNtId324: and swap the tail shaft housing over from the starion tranny or you gotta cut the floor
TaLoNtId324:
yes
AnThOnYbMe:
ok thats enough
TaLoNtId324: or you can do a wide block 4g64 rebuild it to turbo specs and bolt the starion tranny to with
Old Feb 14, 2007 | 02:05 PM
DC Dave's Avatar
Heavy Artillery Co.
tru i would of never thought of that lol
Old Feb 15, 2007 | 12:37 PM
byondevl's Avatar
Made Of Scars
Stock tranny is AT, I dont think it bolts to the 4g63. Im sure there is one person on the board that has a toyota tranny. I cant find it in the search though.
I cant find the wideblock 46g3 anywhere so far. It is quite elusive.
Old Feb 15, 2007 | 12:46 PM
DC Dave's Avatar
Heavy Artillery Co.
they dont always make AT starion i have a stock 5speed..
what is a 4g63 wideblock?? never heard of that before... u can use a 6bolt 7 bolt which ever u want
Old Feb 15, 2007 | 04:16 PM
byondevl's Avatar
Made Of Scars
You misinterpret...The starion in question is an AT.
Wideblock (SOHC)4g63 came in some aussie starions and a few other vehicles I can't recall. Supposedly it is a direct drop in, then you change the guts from a turbo short block. Im not sure if the shortblock ( DOHC) head will fit it though.
Old Feb 15, 2007 | 04:27 PM
DC Dave's Avatar
Heavy Artillery Co.
ive seen the dohc heres bushurs Buschur Racing - Your source for Mitsubishi racing parts and accessories check it out
Old Feb 16, 2007 | 05:20 AM
byondevl's Avatar
Made Of Scars
Shortblock bolted to a powerglide tranny.
