Need help - radiator wire question
OK I am installing aftermarket fan for radiator. Stock harness has 4 wires:
1. BLACK
2. WHITE/BLUE
3. WHITE/BLACK
4. BLUE/GREEN
And my fan has only 2:
1. BLUE
2. BLACK
I don't want to make a fire so please help me here and tell me how to connect this
1. BLACK
2. WHITE/BLUE
3. WHITE/BLACK
4. BLUE/GREEN
1. BLUE
2. BLACK
not sure but if you have a two wire set up it might not work if you have air conditioning b/c you have four wires from the car for that reason. If not the black wire is a ground and the blue is your power source on your new fan
My guess there is 2 ground wires and 2 'live' wires (LOW and HIGH) on a stock harness. Can I connect 2 ground wires with a ground wire on new fan and a power wire with LO and HI wires from harness?
Since you guys don't want to help I am going to connect 2 (+) wires from stock harnes with (+) on the new fan and 2 (-) wires with (-) on new fan. If my car catches on fire its your fault!
