quick question?
Old Jan 25, 2007 | 12:52 PM
dragon13's Avatar
Default quick question?
unorthodox ultra ss 2G (crank, alt, water pump, power steering) pulley kit
$419.91
Do I need to order new belts? if I do, what sizes for a 1996 420a?
Old Jan 25, 2007 | 01:15 PM
John's Avatar
lol @ tampa
do yourself a favor, or at least one of the following
A) don't waste your money. They aren't worth it
or
B) don't buy the crank pulley, and you should have enough slack to use stock sized belts. The crank pulley will cause more harm than good
2008 AW 335xi coupe - Dinan stage 2 - DCI - Dinan axle back
|Full color business cards||flyers||postcards||more|
Old Jan 28, 2007 | 06:05 AM
dragon13's Avatar
thanks
Old Jan 28, 2007 | 07:08 AM
2g's Avatar
2g
I would have to disagree with John on the crank pulley. The rest of the pullies are a waste of money. The underdrive pulley on a 420a is different then a 4g63t. Its not a harmonic balancer. On a NA 420a you get more gains from the UDP then you would from most or any other mods. The aftermarket UDP is smaller then the stock 420a crank pulley and will require different size belts. If you choose to... Howell Automotive sells the AF/X UDP pulley which comes with the belts. This pulley is recommended by many. As of last week mines being machined, they ran out, should be here soon.
If you don't believe me then you can research it on 2GNT.com
Old Jan 29, 2007 | 07:30 AM
dragon13's Avatar
ok
