need help asap (my car is sittin on blocks)
just get rid of them. run the fpr off the intake, then all you need is the bov line and master cylinders source in the back.
SUCH IS THE RULE OF HONOUR.
yea take all the lines off the intake manifold where those three split off near the throttle body. make sure you got a fuel pressure reg. (mine is coming from the far right of the manifold) and a line to your blow off valve. and if you have a boost controller hook a line to that(mine comes from the middle of the manifold theres a nipple coming out of it) make sure you have your brake booster and pcv line hooked into the manifold, and that should be it, just block off any nipples that dont have lines on them.
Srqspeed.com
-Dane
98 240 w/ bolt-onsSrqspeed.com
