Power Steering
Old Dec 25, 2006 | 05:04 PM
Aardvark's Avatar
Default Power Steering
Aight I was goin to are storage this morning and steering and everything was still perfect workin i pull up to the storage gate get inside the gate and the parking lot is flooded and its pourin down hardcore i get down where i have to turn and my steering went out and all my dash lights came on but my car was still running and everything i get out to see if my belt broke or somethin cause its been squeling like a stuck hog for a while now the belt wasnt broken or anything but when i resarted the car everything started movin and workin right but i get around the corner it goes out so im sittin there tryin to figure out and im sittin there and my sis is turnin the wheel for me and when the wheel started to turn the the pulley stopped movin and the belt kept goin so i guess its power steering pump swap and i was just wonderin if anyone else had that prob lmk
/| ,[___],
l---L--[]llllll[]-
()_) ()_)----)_)
Old Dec 25, 2006 | 06:55 PM
95GST's Avatar
boost is your friend
i got a pump if you need one
Old Dec 26, 2006 | 03:14 PM
Aardvark's Avatar
this sucks i just went to the parts store and got one ordered from lakeland for 150 so ill get it tom but thanks anyways
/| ,[___],
l---L--[]llllll[]-
()_) ()_)----)_)
Old Dec 26, 2006 | 03:17 PM
2g's Avatar
2g
What kind of car year, make, and model? I would inspect the belt as well and the pulley and the tension. If its the 420a motor (95-99 Eclipse GS/RS or 95-97 Eagle Talon ESi) I would check the tensioner and pulley. Give us some more info on the car.
Old Dec 26, 2006 | 03:27 PM
Psi TERROR's Avatar
Sounds to me like your alternator/belt.Your dash lights were on but your car was still running?
Old Dec 26, 2006 | 06:17 PM
Aardvark's Avatar
Its a 95 gst and yeah the car was still runing but all the warning lights and lights were on like the ones that are on before you start up and i know for sure that its the power cause when i turned the whell you could see the power steering box lock up
/| ,[___],
l---L--[]llllll[]-
()_) ()_)----)_)
Old Dec 26, 2006 | 11:12 PM
AnthrAxNSB's Avatar
first
How wet was it? Maybe the belts were slipping.
Old Dec 27, 2006 | 11:18 AM
Aardvark's Avatar
It was wet but it wasnt wet enought to get the belts cause i was watchin the belts while the car was runing and they werent slippin but i got the problem solved i got the new pump and everything works fine for now
/| ,[___],
l---L--[]llllll[]-
()_) ()_)----)_)
Old Dec 27, 2006 | 03:32 PM
Skyline Driver 5's Avatar
round and round it go
Damn same shit happened to my car. I dont mean to bash your thread but I just had the same problem, alot of squeaking for a couple days and all of a sudden the power steering completley goes out. So I had to get a $16 belt from AAP that went around the alternator, water pump and power steering belt. Now the car runs fine but squeals wherever I go and it sometimes goes away. I put some WD40 to stop the squealing but nothing worked as of yet. Im gonna check the alternator pulley and how its positioned tonight, if the pulleys not straight and lined up right, your shit will squeal.
TR "Old Skool EF" Member #150
Old Dec 27, 2006 | 03:55 PM
Aardvark's Avatar
the squeling i had was annoying and you could here it from a few blocks away but after changin the power steering pump it doesnt squeal at all as of right now
/| ,[___],
l---L--[]llllll[]-
()_) ()_)----)_)
