clutch problems need help!!!!!!!!!!!
Guest
Posts: n/a
i just replaced my clutch and it wouldnt dis engage so then i changed the slave cylinder and it didnt work so i changed the clutch master cylinder and it still wont dis engage ive had the tranny out 3 times i checked the pressure plate flywheel and clutch disc there all fine the slave clinder is pushing the clutch release fork in but i still cant get it to go into gear. if you can help me pm me or just call because i dont come on often 727-831-7478 Allen
Guest
Posts: n/a
the pedal engagement can be really bad sometimes and its too far away and cannot travel far enough to push the clutch enough to disenguage it. happened to me when i put in a new clutch, adjusted the rod that goes into the master cyliner so it was closer to the master (turn it clockwise), and it went into gear fine. also something you may need to do when you put in a new master cylinder.
Srqspeed.com
-Dane
98 240 w/ bolt-onsSrqspeed.com
