how do you.....?
Old Oct 27, 2006 | 02:53 AM
mitsu420aT's Avatar
Default how do you.....?
how do you bolt up a 3 inch down pipe to your stock os housing ? mine will let me put one nut on but it wont allow enough room to get the other nut on.
Old Oct 27, 2006 | 03:05 AM
DSMboost97's Avatar
How long will it last?
Use skinnier nuts?? Jerry had to use the air chissel in my DP to make a little more room for the nut.
Old Oct 27, 2006 | 07:37 AM
bagabonesGSX's Avatar
A lot of times aftermarket parts dont come perfect, I would get a dremel or similar tool and grind out the hole.
Old Oct 27, 2006 | 09:21 AM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
you have to slot the hole so youll be able to slip it on.
SUCH IS THE RULE OF HONOUR.
