What does your DSM need fixed?
Old Oct 11, 2006 | 02:26 AM
DSMboost97's Avatar
How long will it last?
Sunroof Sunshade
Small oil leak
Clutch master and slave cyliders
Brake job
Small exhaust leak
Get new drivers door handle painted to match the car
Bigger injectors
SAFC or something to tune with
Probly a bunch of other little things, just cant think of them right now
Old Oct 11, 2006 | 05:06 AM
Flaco_GST's Avatar
Master of the cut-off T'S
Radiator reservoir bottle....wideband (hint hint kevin) tune...
...Only god can judge me...
"If you don't set goals for yourself, you are
doomed to work to achieve the goals of
someone else."
Women might be able to fake orgasms but us men can fake a whole relationship.
V-TEC = Virtually-Torqueless Economic Cars
(PROG) Crew member #5
{o,o}
|)__)
O RLY?
Old Oct 11, 2006 | 06:07 AM
Psi TERROR's Avatar
Oil cooler housing I need one!!!!!!
Old Oct 11, 2006 | 06:44 AM
Tom N's Avatar
Non DSM.....DSM guy
Originally Posted by DsmInduction
you get your pistons?!
They will be here soon.
Tom
Old Oct 11, 2006 | 07:36 AM
2gntTalon's Avatar
I need a new pass. side a/c vent because mine is cracked, exhaust manifold, pipe fabrication, MS, injectors and get my tuning face on
eclipsegst303's Avatar
.:DSM:.
Change brake rotors/pads, fix leaky sunroof, fix low compression.....Other than that, its running great.
Old Oct 11, 2006 | 08:09 AM
  #17 (permalink)
Jordan Y.'s Avatar
15 seconds EXHILARATION
Replace brakes (and upgrade, obviously). New water pipe. New thermostat. Paint. Fix MAF. Mount battery properly. Lots of other stuff.
Old Oct 11, 2006 | 08:23 AM
  #18 (permalink)
Chris LS's Avatar
just blaze...
Door handle, Lower ball joint (recall, will be fixed on Monday)
Quote : I'm Slow:
Less hours = less $$. Less repetitive 'ish every day = PRICELESS!
Old Oct 11, 2006 | 05:26 PM
  #19 (permalink)
zeb0r's Avatar
i think the true question is.. what doesnt need to get fixed. :/ or whats actually running great!@%!
Gone ..... mitsu ev0 8 mr
makin it happen in.... lex is300
Old Oct 11, 2006 | 05:34 PM
  #20 (permalink)
dsmdreamer's Avatar
motor wise mine runs perfect. all i honestly need is to....
*fix, power locks (they dont work)
*get a new track for my passanger side power window (cause the glass shakes inside the door.)
* oil leak from rear main seal (will fix whenever i drop tranny to do clutch job)
other than that mine is perfect.
