Need suggestions for performance mods...
Old Oct 2, 2006 | 09:05 PM
So_Sli's Avatar
Default Need suggestions for performance mods...
So, I'm buying So*Simple*GSX's Eclipse, and I need to know what would be suggested that I mod. Okay, here are the mods the car already has:
  • Front and rear strut bars
  • Shortened intake w/ aftermarket filter
  • BIG FMIC
  • Non-recirculated dual-horn BOV
  • 3" Downpipe
  • Aftermarket Exhaust
  • XTD Stage-3 Clutch (approx. 10,000 miles)
  • Autometer gauges (boost, oil temperature, A/F ratio)
The most recent maintenance on the car has been:
  • New waterpump and all the belts
  • Timing belt
So far, this is all (that I know of). I'd like to spend $2,500 in mods on it shortly after I buy it, but I'd like to know what you guys would suggest in terms of parts, stores, and where to get it all installed.
Please note that the car has 142,000 miles on it, but it feels like it was a babied 142,000 miles. Still, that much mileage on a car, especially the engine, has to have SOME effect on what extent I can go to with modifications.
Anyway, if you know what car I'm talking about, and especially if you've worked on it, please let me know what you think would be best in terms of mods. Again, I'll be spending between $2,000 - $2,500 in parts AND labor.
So far, here are all my performance modification plans, but I don't know what brand to buy, store to buy it from, shop to have it installed, or order to buy it in. I know all these mods will exceed $2,500, so that's why I need to know what would be suggested to get first:
  • Dual intake temperature gauge (I'm thinking of putting the 2 sensors before and after the intercooler, so I can see how well THAT's performing)
  • EGT gauge (coupled with the intake temp. gauge, I'd be able to see the temperatures before the intercooler, after the intercooler, and after exiting the engine)
  • Voltage gauge (do I really need this?)
  • Oil pressure gauge (do I really need this?)
  • Water temperature gauge (do I need this if I already have an oil temp. gauge?)
  • Boost controller (should I go for manual or electronic?)
  • Larger turbo (I was thinking 20G would be sufficient for a while, but I'm open to suggestions)
  • Fuel pump (I'm considering a Walbro 255lph, but again, I'm open to suggestions)
  • Fuel pressure regulator (will I need this?)
  • External wastegate (I've heard this REALLY helps spool-up)
  • Larger injectors (I'm considering 550cc, but let me know what you'd suggest)
  • Lightweight flywheel
  • Intercooler spray (should I just get water-cooling, or is it worth it to invest in a nitrous-cooling system?)
  • Exhaust manifold (I've heard tubular manifolds are good, but should I get ceramic or steel or what?)
  • Intake (anyone ever heard of the Blitz SUS filter? I'd like to pair this up to a metal intake pipe. Suggestions, anyone?)
  • Stainless steel clutch line (I've heard this maximizes the amount of pedal force transferred to the slave cylinder)
  • Shifter cable bushings
  • Short shifter (I'm deciding between B&M and Fidanza, but I'm open to suggestions)
  • Motor mounts
  • Cams (my friend suggested I get cams, but how do these help performance?)
  • Radiator (with the mods I am looking forward to installing, I'm sure upgraded cooling will be necessary, but what do you say?)
  • Fuel rail (will this be necessary soon, or far down the road?)
  • Spark plugs & wires (realistically, how much do new spark plugs help?)
  • Capacitive discharge ignition system
  • Suspension upgrade (should I get coilovers or springs? What shocks would you guys recommend?)
  • Brake rotor and caliper upgrade (suggestions or reviews, anyone?)
  • Stainless steel brake lines (I've heard this stiffens up the brake pedal)
  • Electronics (Turbo timber, and air/fuel controller or EMS? Suggestions?)
  • Upgraded rear spoiler (this car has the low-profile spoiler, but since it's AWD, I would like to install a larger wing. Not some huge ricey wing...I want something functional. Suggestions?)
Okay, it's late, and I can't think of anything else off the top of my head, so now I'll leave it to your guys to let me know what you think I should do. Thanks in advance!
Old Oct 2, 2006 | 09:22 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
as far as guages id just get an oil pressure gauge, boost and wideband.
-boost controller (i prefer electronic, either will work fine, but if you do get a manual get a joe p)
-turbo depends on how much power you want
-anything bigger than a 16g you want an external gate
-255 fuel pump will be good
-id get a AFPR with that, but you dont need it
- injectors- once again how much power do you want?
-flywheel only if you are gonna rev the car high
-intercooler spray- just get methanol injection, youll be glad you did.
-exhaust manifold, id keep the stock one and port it out.
-intake, just get whatever, its not gonna make a difference
-motor mounts, yes you want those
- get cams if you want a good powerband some BC's probably 272s
-fuel rail, NO the stock one is fine for any power basically
-spark plugs and wires, just get ngk bpr7es
-ignition system(i have no clue what that is, at the most get a coil on plug setup, but i wouldnt worry about that too much right now)
- just get some eibach springs and put em on some kyb struts
-electronics-DSMLINK!!!!!!!! DO IT! it will let you read intake temps too, so dont worry about those guages.
-as far as spoiler, do what you want with that, personal taste there
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Oct 2, 2006 | 09:26 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
oh and for injectors, it sounds like you want to make some good power since you want somethin along the lines of a 20g, so id get some 850s, but you wont get the car to run completely right without a standalone like dsmlink.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Oct 2, 2006 | 10:41 PM
Lay Maha's Avatar
Jaded Mitsu
wow, big plans g/l.
Old Oct 3, 2006 | 07:10 AM
DSMboost97's Avatar
How long will it last?
Stage 3 clutch on an AWD 7 bolt car with 142,000 miles? Might wanna think about spending the $2500 on a 6 bolt swap. Just my opinion though. Good luck with the car, sounds like you have big plans. Oh and do yourself a favor and get the 2GB turbo wing, best looking wing ever!
Old Oct 3, 2006 | 08:41 AM
So_Sli's Avatar
I have an Eclipse in the "For Sale" forum with a JDM 4G63 with 45,000 miles on it, a small 16G turbo, 550 cc injectors and a dual-runner intake manifold...not to mention it's a 6-bolt...would it be best to swap that into the new GSX? Can I do that if the transmission is AWD (will it match up)?
Old Oct 3, 2006 | 02:11 PM
JR.'s Avatar
JR.
if the car is runing good , there is no need to do a 6 bolt swap.
u need a maf-t if ur going to be venting to the atmosphere, or aem ems.
98 talon awd automagic
Old Oct 3, 2006 | 02:12 PM
JR.'s Avatar
JR.
+1 with the front and back bumpers and side.
Old Oct 3, 2006 | 02:22 PM
*SoSimple*GSX's Avatar
Well Hot Damn !
hahaha charolettes gettin a make over ! i like the big honkin wing as well.
Karen
Originally Posted by senor honda
Driving is like sex: Everybody does it. Everybody thinks they are good at it. But some are a LOT better than others!
Old Oct 3, 2006 | 02:35 PM
So_Sli's Avatar
Charolette's most DEFINITELY getting a makeover, but for now, I'm planning on working on the internals (interior, engine, etc.) before I do anything like body kit or paint, etc. I can get 2 black Ralliart seats for $220, shipped. I have connections.
