Another "DSM with a problem" thread
how does the car idle at other times, like startup and etc.
SUCH IS THE RULE OF HONOUR.
Car idles fine at startup and after i come to a complete stop, other than a lil miss everyonce in a while. If im just sitting in a parking lot or something in neutral and rev it up, the idle drops very low again as if im venting but i checked the dump tube and re-taped it and no difference. sometimes it does it, sometimes it doesnt.
is there a vac leak somewhere you dont know about?
No vac leaks, and it only does this when it feels like it. It could be running horrible on the way to work and on the way home it will be fine. Most of the time it doesnt run right but every once in a while it will run fine.
Dont have a pocketlogger and im definately not going VTEC. lol. Maybe ill get all the CEL codes scanned and see if its throwing something that might be causing the problem.
