What kind of turbo is this?
round and round it go
on
My car is smoking white smoke, and it smells like oil, plus I have an oil leak from the pan. The car seems to run fine and smooth but when im flooring it, the turbo sounds like its cutting in and out. I was putting on an FMIC yestereday with Damon from Twin Cam and there was oil in the pipes and in the turbo. Could this be why my car is smoking. I hope its not piston rings or a head gasket? What should I do? If it is the turbo, would this be a good replacement? Your input please.
TR "Old Skool EF" Member #150
I cant tell what the second to last number on it is to identify it, but I will say that is not a direct bolt on. It might be a turbo from a conquest/starion but I cant be too sure which car its from.
I would look for other means of a replacement. Maybe another T25 if you dont plan to mod your car anytime soon, but thats my .02 worth.
on
Lemme take a better pic, I dont think its from a GST because the o2 housing doesnt look like it would bolt up to the compressor.
Your not going to have oil in the compressor housing from a headgasket or piston rings.... That would make your car smoke.
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
on
The second picture reads 49178-01740 S, I got this turbo from my friend. Yesterday when I pulled the intake off, there was a little bit of oil in the turbo and when I ran my finger around every pipe and there was oil on my finger. Anyone had a similar problem like this before?
I cant tell from the size, it almost looks like its from from a diesle truck.
It has the twin blades like an evo 3, but that oil line ive never seen before, not on a dsm anyhow.
Somewhere on dsmtuners is a chart with every mitsu turbo vin number fro cross refferencing
edit...part number is for a TDo5-10A, im trying to find out what it is from. It looks close to and 16G.
I think the conquest was a tdo5-12A
I cant read the second to last number...but it looks almost identical to
the conquest turbos here
http://www.eastcoastturbo.com/Secure...asp?offset=150
its a quest 12a turbo. looks like a nonintercooled model because of the outlet angle and munchkin housing.
SUCH IS THE RULE OF HONOUR.
