didn't that car loose on pinks??? any motor with money can make alot of HP i am refering to the single cams u actually see on the street.
98 talon awd automagic
Yeah the Full Race pink car lost on pinks. If you read the article:
"It took 30 lbs of boost to make 460 whp on a stock sleeved D-Series. I guess the rumor that stock sleeved D-Series blocks not being able to take high horsepower is false."
- Evans Tuning
Thats 18lbs of boost more then 12lbs of boost. Depending on the supporting mods, give or take what turbo and boost setting that will determine the outcome but you don't know until you run.
- Evans Tuning
Josh (cliffaller) had a 95 Si hatch with a d16z6 running 11psi (low boost) and he would walk stock or semi stock STI's from a roll. He had a 57 trim t3/t4.
10 sec street truck...
- Evans Tuning
- Evans Tuning
