Started the work!
Old Aug 23, 2006 | 11:52 AM
Green_Lantern's Avatar
Green Lantern Corps
Default Started the work!
Yesterday i finally got time to pull the head! I took an hour or two to get it off. The guy that had it before me have all the vac hoses disconnected for some reason. But once i pulled the head off i noticed a lot of things wrong. Such as huge gashes on the cames, The valves and pistons made a lot of contact, the car ran extremely lean, and when i took the oil pan off it had shaving of metal in it . So i got a lot of work a head of me. But here are some pics...
If you're not cracking oil pans your not low
Old Aug 23, 2006 | 03:45 PM
Figs's Avatar
Good luck with it all. I see there's aftermarket parts that would be great to use with a build.
Old Aug 24, 2006 | 11:22 AM
Green Lantern Corps
Ya things could have been a lot worse. But most of the stuff i can reuse so im happy about that. Oh well next to be pulled is the block and tranny ill post some pics of it once i get it out.
Old Aug 25, 2006 | 01:47 PM
Dario99gst's Avatar
Tu Papi Chulo
gl!
Edit: What makes you think the pistons and valves came into contact?
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Aug 26, 2006 | 11:32 AM
Green Lantern Corps
Originally Posted by Dario99gst
gl!
Thanks man. Its hard to see in the pictures but the valves a chips in them and the pistons have some nasty looking indentations where it looks like they have been slammin each other.
