What Would Cause No Spark For My Motor
The Hole Fucking Engine Is Brand New And No One Can Seem To Fucking Complete It
Please I Need All Factors What Would Cause A Motor To Have No Spark Please Help Me Thanx
I Have A 4g63t 1st Generation 6 Bolt Motor
busted coil packs?
wiring harness that sends the signal to the coil packs (and subsequently to the wires/plugs) is busted or not plugged in.
1998 Eclipse GST
1998 Eclipse GST
try the transistor pack. pretty much what hes ^talking about, sends power to the coils.
SUCH IS THE RULE OF HONOUR.
I have never seen a bad set of coils. The power transister looses one of two circuits when it goes bad. So the car will run on two cylinders. I would try a known working ECU.
my favorite quote
my favorite quote
my car is at sidewinders on ulmerton and 66st i f u have a ecu i can get a hold of hit me up asap i need my car running the hole motor is new y wont it run he said see if i can get a turbo ecu so hit me up on my cell 727-244-8277 if u can help would really appreciate
ILL CALLED UR SHOP WHAT CAN U DO TO HELP ME
OUT HERE IS MY NUMBER I NEED MY CAR Back in the road been out of order for 6 weeks now 727-244-8277 is my number if u can help me call me thanx
they just redid my head thats it bottom end was done at motorhead performance can u help me what do u think it can be im replacing cam angle sensor and in process of finding a new computer
