AWD conversion
Yeah, the AWD conversion is not really necessary, unless your plans are to put some serious power down.
Also depends on the type of racing you plan on doing with it. The AWD will definently help in drag situations. If you happen to do a lot of high spirited driving from a roll, then it's actually detrimental to have an AWD setup.
wow......... why are yall saying that awd is not necessary unless u plan are to put some serious power???????
awd is 100 times better then fwd with a t25 or a 35r it does'nt matter...... if i had a 2g gst that would be the first thing i would do make it awd .....
my boy use to have a awd 1g and use to beat alot if not most of the v8 that he races being awd, then his t-case fucked up so he was fwd and he could'nt beat a MAZDA PROTEGE... with that same setup 16g at 17psi stock engine .......
98 talon awd automagic
Originally Posted by GsEclipse02
how many real races happen from a dig ...??? and i am not talking about those bull shit races you go to off of cause way
go to N2S and see how many of there videos are from a dig... not many and onnce you start break shit you will be going from a roll also ...
its not that my car has to mucchh powwaa for the FWD setupp.. drag radials will fix it all.. I got solid motor mounts and a few other things to help that out..
AWD is just fun.
AWD is just fun.
Totalled his shit!@
Totalled his shit!@
I agree that an awd setup is far more superior and will garner better results with almost any setup, but it may not be worth the cost if he doesn't plan on modding it very much.
I'd like to run a much larger compressor in the future (waiting for my 7 bolt to eventually walk). Besides the couple small mods I have done to my car, my first big mod, was going to an AWD setup. Then I would have a great platform to work with from there. I'd like to run a 30R or 35R eventually and the AWD would definently make driving the car that much more enjoyable and quicker.
Add a nice Cyclone mani with the Jerry T-25 actuator mod (as well as the whole list of other necessary parts to run a 30-35r series) and you have one sick ass machine.
