nitrous setup questions?
Old Jul 13, 2006 | 06:19 AM
GsEclipse02's Avatar
Ps get a wide band or go to a dyno to do your testing
Old Jul 13, 2006 | 09:30 AM
F4A22's Avatar
Old School
Originally Posted by GsEclipse02
i was just basing it off of all of the srt4's who sprayed
Exactly a srt has a 16g.....
Old Jul 13, 2006 | 03:31 PM
dewey04's Avatar
I didn't get ahold of anyone from a nitrous company too busy but i called a buddy who drives a outlaw 10.5" car he is verry good at nitrous. He said it is better to run a lower fuel psi because alot of systems do not atomize the fuel n2o mixture correctly past 20psi of fuel and if you use larger fuel jets you will have less problems. He also said you should not have to change jetting for boost but if you jet it richer it will help spool the turbo faster. I dont know if the fuel psi is for when you are using a fogger and it wouldn't matter with a single jet system but i'll find out later.
Old Jul 13, 2006 | 03:32 PM
dewey04's Avatar
i have a wide band what afr should i go for?
Old Jul 13, 2006 | 04:05 PM
Tom N's Avatar
Non DSM.....DSM guy
Depends on what fuel you are running.
Tom
