another dumb question
Old Jul 8, 2006 | 06:49 PM
mitsu420aT's Avatar
Default another dumb question
how many extra psi of boost can you add to a 97 gsx/t-25 with out a safc or dsm link ect. i have a 3'' down pipe , no cat and a 3'' cat back...
just a boost controler?
you know , just turn up the boost with no extra fuel control.
Old Jul 8, 2006 | 07:02 PM
BDIX's Avatar
Dick is Huge!
16psi... although I'lll spike 18.
Totalled his shit!@
Old Jul 8, 2006 | 07:11 PM
mitsu420aT's Avatar
all i have is a full 3 inch exhaust and curently still smic..... i wanna up the boost with a mbc but .....can you do that with nothing to tune with..... i mean just a couple psi or is that a no no...
Old Jul 8, 2006 | 07:24 PM
BDIX's Avatar
Dick is Huge!
I'm doing it... with a unrecirculated BOV and a stock fuel system... check the war storys
Totalled his shit!@
Old Jul 8, 2006 | 08:28 PM
BoostLogik's Avatar
BoostAddict
I would just go rougly 2-3 psi higher at most, over stock.
Anything more, the turbo is just going to spike and drop in pressure (the turbo is just too small and literally runs out of breath). Any higher than 2-3 psi, you're just putting unnecessary strain on the compressor and prematuring it's life.
If you want to boost harder, get a larger compressor, fuel, and the necessary management tools and gauges.
Old Jul 8, 2006 | 08:30 PM
mitsu420aT's Avatar
^ thanx for the info... i have a super 16 g i believe it is off of a 3000gt. i think... will be swapping soon
Old Jul 8, 2006 | 08:45 PM
BoostLogik's Avatar
BoostAddict
Anytime bro.
I'm assuming the 3000GT VR4 was modified? The stock turbos on VR'4s were either TD04 9b’s or TD04 13G’s, not 16G's.
Old Jul 8, 2006 | 10:33 PM
LS1Fever's Avatar
Kevin, next time we meet up, bring that turbo with you so that I can identify what you have.
Old Jul 8, 2006 | 10:58 PM
Dario99gst's Avatar
Tu Papi Chulo
15 PSI is what I would run. From personal experience it really didn't make that much of a difference. You can actually run that kind of boost without the boost controller. all you have to do is take the inside restrictor of the stock boost solenoid.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Jul 9, 2006 | 05:52 AM
Figs's Avatar
15 psi I think anything higher then that without supporting mods (fuel mods and such) will result in fuel cut.
