Not Sure...?
Old Jul 3, 2006 | 07:49 PM
Proracer05's Avatar
Default Not Sure...?
hey guys i was wondering if this will fit the stock turbo of a 95-99 GST Eclipse, would it be a good buy? thanks
http://www.horsepowerfreaks.com/pric...aust_Manifolds
Joel's Quote:
I'm not your Man
You're not my Girl
So, Technicaly I'm Not Cheatin'
Old Jul 4, 2006 | 07:34 AM
Dario99gst's Avatar
Tu Papi Chulo
to answer your question yes it would but the placement of the turbo is different so you MAY run into some issues with the exhaust lining back up.
Now after having said that why in gods name would you invest on an aftermarket tubular manifold when you haven't upgraded your turbo? Our stock manifolds have been proven up to crazy amounts of HP (I don't know the exact numbers but I'm sure someone on here does) Spend the money on your supporting fuel mods such as injectors fuel pump fuel regulator and some sort of tuning tool. then start saving for whatever turbo you want. and while you are doing the swap take your exhaust manifold to Jerry for some porting. (That's what I'm running in my car do you need a ride?)
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Jul 4, 2006 | 08:03 AM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
i can port it too.
SUCH IS THE RULE OF HONOUR.
