Crank pulley wobbling
I finally got my 6-bolt put together and went to crank it up. While my friend was turning it over i noticed my pulley was wobbling. I am hoping the crank isn't scrapped. Let mw know what you guys think!
FS:FT: Sc300 parts and 2jz swap. LOOK!!!!
nah... Its probably just that the rubber dampener seperated from the pulley itself. Just replace it and you should be fine. I just replaced one on my sis' spyder
they go bad after time. sometimes they seperate. I have one laying around somewhere i think, if you need one cheap.
SUCH IS THE RULE OF HONOUR.
I fixed it, come to find out the guy who did work on it before me put the pulley on wrong, so the timiong belt was getting ate up on one side. I put it on right though!
