Problems
Old Jun 26, 2006 | 05:34 PM
DSM-Doin'em's Avatar
White Trash Racing
Default Problems
Well, hows it goin everyone, im kind of new here, i've been on TR a while but havent posted in like 9 months so i figured i would re-introduce myself... My name is Tyler, i drive a 95 eclipse with a 6-bolt and lots of mods... i also like long walks on the beach, kittens and puppies, romantic candle light dinners and did i mention im a scorpio?? lol j/k but anyways i need some help and i was told by a few friends you guys were the ones to come too... something is up with my tps, if i drive in 5th gear for like 1 minute at any speed over 60, my car throws a code, and its like it cuts down to 2 cylinders and goes completely lean...?? but if i push the clutch in and it idles for a sec it goes away but comes back a few minutes later if not sooner.....?? If i unplug the tps it doesnt happen... i just dont know what to do, any ideas would be great, just pm me or post.. thanks everyone...
Tyler
TR's WTR Crew Member #05..
Originally Posted by Teamcalloway03
Arrrrrrrrgggg!!!.
Old Jun 26, 2006 | 05:39 PM
Dick's Avatar
Hell on wheels
try a new tps sensor
Old Jun 26, 2006 | 07:00 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
no no no, its the random 6 bolt missfire, your gonna need dsmlink or the tps barometer mod(which ive heard some bad, but personally havent had any trouble). i dropped it down to 4th and boosted it and it went away for a while once.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jun 26, 2006 | 08:01 PM
White Trash Racing
ya i tried 2 new tps sensors...
and where can i get dsm link and how much is it?? im actually about to get rid of my s-afc and get the e-manage, will the dsm link interfere?? i have the scan tool to read codes and it comes up with a few i've never heard of like "purge valve c fault" ??? and it came up with a "tps malfunction" i just dont know anymore, i mean i did a lot of the work but when it comes to the electrical stuff like that im clueless... so if i can bring my car to someone to check it out i will make a drive no problem, someone just let me know... thanks for the help so far..
Arrrrrrrrgggg!!!.
Old Jun 26, 2006 | 08:05 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
its beacuse the 6 botl swap, you could try the barometer mod
-Dane
98 240 w/ bolt-ons
Srqspeed.com
BOX SENTRA's Avatar
OG MUDBONE 240sx
and dsmlink is 600 bucks with the ecu socketing which you need. and your ecu is probably eprom so your good there
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jun 26, 2006 | 08:11 PM
White Trash Racing
Well if anyone has a dsm link for sale please let me know.... thanks for the help..
Arrrrrrrrgggg!!!.
Old Jun 26, 2006 | 09:29 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
theres no easy way to fix this besides dsmlink, a potentiometer on the barometer wire leans out the engine, It involves taking a Radio Shack style volume knob and manipulating the
barometric/atmospheric signal to the ecu. You can lean out an
engine this way and fry it. TPS disconnect is better temporary mod to get the RM to go away. DSMLink is a much better solution that most importantly gives you the ability to tune your car.
temporary solution.... .the cure is DSMLink...the temp. solution for it is pull the TPS
sensor...you'll probably get crappy gas mileage but it beats pulling over
and reseting the
ECU...hope this helps
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jun 26, 2006 | 10:01 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
if you have an safc use a map sensor to replace the tps so you can still have a high and low throttle setting, except it will be controlled by boost
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jun 27, 2006 | 06:04 AM
Kristin's Avatar
call me Gangsta boo
Tyler Floridino?
Please check out this link...
http://www.BeautysEquineRescue.org
