breaking up
i have a stock 97 gsx and when i go into boost it starts to break up. i have doone searches and i still dont know what it could be. i deleted the boost controler ( maybe it was faulty) ( was on stock anyways) and it still does the same deal. ant ideals of what to check
i do have a check engine light , but it is the fuel pressure silinoid. ( which i need the part # as well if you guys happen to have it.
thank you
rep will be handed out for your time.
thank you
Do you have new wires? A friend of mine has a GSX that was doing the samething, as soon as you started to get on it it would sputter. We changed his wires and it went away.
DSM Part Out
DSM Part Out
mine dosnt stutter it feels like it either leans out or boggs down , i am not sure what each feels like exactly , well i know what it feels like when it leans out , but not sure if that is it or not. any more i deals.
new plugs and wires maybe. i had this problem but it was cause i had aftermarket injectors and no afc and it would work fine and then foul the plugs, cuase i would put new plugs in a nd it would work for a minute and then foul them
Srqspeed.com
-Dane
98 240 w/ bolt-onsSrqspeed.com
