Starting to think i should have bought a Honda.
Old Jun 11, 2006 | 09:30 AM
DSMboost97's Avatar
How long will it last?
Default Starting to think i should have bought a Honda.
Its always something with my car, anyway, i have a problem. I just put a new FMIC and piping on this weekend. When i go to test drive it to make sure everything it working smoothly, it doesnt wanna run right. It fires up and idles wonderful now, and when its in neutral and im not moving i can rev very smooth and as high as i want with no problems. But, when i put in in gear and start moving, when i let off the gas pedal the RPMs drop way down near 100 - 200, and bounces back up to normal, or it drops so low that it stalls. It feels like the exact same symptoms as when you dont have your recirc tube connected. And its not the intercooler becuase i had to go somewhere when i was half way through the install and i still had the stock sidemount connected and it did the same thing. Anybody have any ideas? Thanks for any help.
Old Jun 11, 2006 | 11:33 AM
seventhgear's Avatar
hanglike sleeve of wizard
is the bov faulty? maybe needing of some adjustment? maybe try ricirculating the air back into the engine to see if it could be a faulty bov... just some sugestions and hell, i suck with turbo setups. ask brothers or lancerman by pm.
image removed from your sig...see forum rules
Old Jun 11, 2006 | 12:41 PM
DSMboost97's Avatar
BOV shouldnt be faulty, worked fine before i put the intercooler on. Ive always had it recirculated so that isnt the problem.
Old Jun 11, 2006 | 01:11 PM
BDIX's Avatar
Dick is Huge!
you dont want a honda.. I was considering one.
I love my car. The problems happen but overall DSM's are great.
Totalled his shit!@
Old Jun 11, 2006 | 01:17 PM
2ndGenDsm's Avatar
maybe u shouldve had someone do it???
and now introducing my newest toy...
-Silver Slow-poke-
Old Jun 11, 2006 | 01:51 PM
sorry i couldnt help
Old Jun 11, 2006 | 04:00 PM
DSMboost97's Avatar
I wasnt serious about getting a honda, i love my baby and would never give her up. I dont think having somebody do it would have avoided the problem. the installation is pretty simple. Went back today and took off some of the piping and reconnected to make sure everything was tight and secure and still the same problem. Maybe tomorrow ill take everything off and return it to stock and see if there is still a problem. i really dont want to do that and im pretty sure its nothing to do with the intercooler or piping, its all solid and tight.
Old Jun 11, 2006 | 04:31 PM
lancerman's Avatar
you made a change to the car and now its not running right. 99% of the time it is something you did wrong. most likely a boost leak or vacume line disconected.
my favorite quote
Old Jun 11, 2006 | 07:22 PM
DSMboost97's Avatar
I completely agree that when you make a change and it doesnt run right youve most likely done something wrong. But i am almost positive i didnt do anything wrong, it not exactly like i tore the engine apart and tried to piece it back together, just replaced intake piping and some couplers and clamps, not exactly rocket science. All vaccum lines are connected and i didnt find any boost leaks when i tested it. Decided to take the car on the road a lil and see it driving on it a little would change anything. Sometimes it seemed a little worse and sometimes it was almost gone.
Old Jun 11, 2006 | 07:27 PM
LS1Fever's Avatar
Just go over everything with a fine tooth comb and make sure everything is connected. It may seem that you installed everything correctly, but you may have boost leaks. I would do a boost leak test just to be certain.
