Help
Old Jun 9, 2006 | 10:51 AM
me's Avatar
me
Default Help
Any clue what this light is for? It just came on today. I don't have a manual for my car and tried searching on the internet for something to show me what each light means, but had no luck.
Old Jun 9, 2006 | 11:19 AM
A97EclipseGS's Avatar
Dude it looks like its overheating.Like a low coolant light
Clean 420a
Old Jun 9, 2006 | 11:32 AM
Stephan's Avatar
I do believe you are correct. I think it is the low coolant light.
DSM Part Out
Old Jun 9, 2006 | 05:23 PM
Figs's Avatar
It is the coolant light. Usually comes on when your over heating. Low on coolant/have a leak and other instances. What I would do first is check the coolant resevoir which is located on the passenger side near the fan. You'll see a hose from the thermostat housing (where the radiator cap is) that runs to the coolant resevoir. It maybe low on coolant and if it is the sensor inside will trigger the light. This happened to me before. I added coolant to the resevoir and the light went away. Thats what I would check first. Then if the light is still on replace the radiator cap and if its still on replace the thermostat (it maybe stuck). Try those few things and see what happens.
Old Jun 9, 2006 | 07:42 PM
me's Avatar
me
Added coolant and it worked. Thanks for the quick help.
Old Jun 9, 2006 | 08:03 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
seems your bird flew out of the cage
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jun 9, 2006 | 08:08 PM
GsEclipse02's Avatar
